All the lumanation dash lights went out.
Old 03-18-2016, 12:23 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
02GrayPowerStroke is offline
I was driving home and the dash lights went out. I checked all of the fuses and they all check good. Any ideas?
Thanks
Chris
Old 03-18-2016, 01:21 PM
acogoff's Avatar
acogoff
acogoff is offline
I would give the dimmer switch a whirl and see if that helps the situation.
Old 03-18-2016, 01:38 PM
02GrayPowerStroke
yea did that
thanks
Old 03-18-2016, 02:35 PM
pdqford's Avatar
pdqford
pdqford is offline
If your talking only the illumination lights in the dash, check their ground over in the passenger kick panel.
Old 03-18-2016, 04:24 PM
02GrayPowerStroke
I think your right, but there are 2 hundred cables under there. Do you know what cable it is?
Old 03-18-2016, 07:40 PM
02GrayPowerStroke
I checked the only grounds I could sèe. Are there more?
If not are there any other suggestions?
Old 03-18-2016, 07:49 PM
pdqford's Avatar
pdqford
pdqford is offline
Black. It also provides a ground for many other things, like the ashtray light, 4WD switch light, etc. Did they also go out?
Old 03-18-2016, 09:44 PM
Travis S's Avatar
Travis S
Travis S is offline
For 97/98, there are THREE ground terminals under the DS Kick Panel. One for the radio/amps/CD Changer/sub and TWO for the dashboard items PDQFord mentioned. Clean them up with a dremel, both the sheetmetal and ring terminals till they shine, temporarily bolt them back down and try it again. If it works again, rust/corrosion was the issue. If not, the next suspect is the Main Light Switch. Consult the Factory Service Manual for a pinout of its connectors and try bypassing it to see if the interior backlights light up. If they do, your switch is the culprit.
The reason I said to TEMPORARILY bolt the ground back on is because it was only to rule them out. If they are corroded, cut the ring terminals off and replace them with new ones, a STAINLESS STEEL BOLT and dielectric grease to prevent moisture from getting back in. This method works every time and will be trouble-free for years to come. Between this and exercising the actuators a bit, it cured my power lock 'wiggling'
Old 03-19-2016, 10:49 AM
02GrayPowerStroke
no the airbag cel ect are still working
Old 03-19-2016, 11:14 AM
02GrayPowerStroke
Old 03-19-2016, 11:58 AM
02GrayPowerStroke
ok call me blind but I can only find one ground. it does have two wires on it
Old 03-19-2016, 12:45 PM
02GrayPowerStroke
I cleaned the ground with a dremil. weird thing the ground disconnected it sounded like g he flashers where on an the door chime was on. weird huh?
Old 03-19-2016, 01:08 PM
pdqford's Avatar
pdqford
pdqford is offline
Is this vehicle the F250 listed in your sig line?
If it is, and its a Super Duty, the instrument panel illumination ground is up under the dash between the instrument cluster and the radio.
Maybe its a diesel?
Old 03-19-2016, 01:25 PM
02GrayPowerStroke
ok fixed it, thanks for the help!
Old 03-19-2016, 08:24 PM
pdqford's Avatar
pdqford
pdqford is offline
Good to hear you gotter fixed.
What was the fix?
Dizz88
19
01-09-2020 03:20 PM
T_199
04-25-2014 05:04 AM
brian Felts
07-11-2010 12:56 PM
Corner Gas
05-07-2008 05:36 PM
gkpettigrew
09-08-2003 10:02 PM
Quick Reply: All the lumanation dash lights went out.
