Need 460 build help
Need 460 build help
I have a 460 out of a '76 F-250. I think it has D8VE head markings. I will most likely be buying a set of D0VE heads from another member.
I want to build something decent for my '78 F-250 SC 4x4 with Dana 60 F&R with 4:10 gearing and a factory C6.
This is not a daily driver, but I do use the truck for:
I am open for suggestions on:
I'm looking to get help from the pros when needed, but I am wanting to do the assembly work.
Thanks a ton!
- Driving on the beach
- Hauling dirt, wood, trash, and ???
- Pulling a new to me 30ft camper through hilly country
- Cam: The engine has a two year old RV cam in it. Is this re-usable, or should I replace it? I can get the specs...
- Crank: I am told mine has two bad journals. Is this an opportunity to get some extra stroke?
- Pistons: The engine is getting bored +.030 over stock
- Intake
- Carb
- Distributor: Is stock good enough, or should I go for an upgrade?
- Head mods: Should I stick with stock rockers go with roller rockers? What about valve work and porting? Other mods?
- Timing: I thought I saw some posts about variations in timing settings and what should be done to correct some retarding issues.
Thanks a ton!
luthoro
07-03-2023 08:39 PM
bigern26
23
09-29-2010 04:01 PM
Ranchero460
08-16-2006 01:05 PM
78Buford
10-03-2005 10:07 AM
Mudman
08-12-2003 09:27 PM
