460 EFI Ultimate Build
Old 03-16-2014, 01:39 PM
saxxbills's Avatar
saxxbills
saxxbills is offline
Now that I have the writeup in my hand I noticed the torque converter. Oops. What were the specs for that? The part number seems to not exist and the Midwest people seem to not be much help. I have called them multiple times and they will not return my call.
  #32
Old 04-05-2014, 02:46 PM
Dbeast71's Avatar
Dbeast71
Dbeast71 is offline
Pics of your headers?
lesoster, you are the only person I've been able to find on google who has used those headers and I'm planning a similar build. Can I please get some pictures?
I think they will work on my 90 manual off-road rig but want to make sure before dropping the coin. Is the outlet 3"? Does it go over the transmission cross-member next to the frame (has to for my application)? If they fit like I think they will I won't even need an exhaust shop, just a piece of 3" pipe and a muffler.
Thanks
  #33
Old 08-24-2014, 12:47 PM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
Thanks
The model for Leo's are for a California ODB2 truck. Different headers. For the 90' you should check Thorley's site.
  #34
Old 10-27-2014, 04:57 PM
GreenMachinee's Avatar
GreenMachinee
GreenMachinee is offline
Originally Posted by lesoster
Unfortunately I do not have any photo's of my regulator install, but the BBK adjustable fuel regulator is an exact replacement for the stock fuel regulator. Simply remove the fuel line nuts from the stock regulator, remove the stock regulator and reverse the steps to install your new BBK adjustable rfuel regulator. The fuel pressure guage can be installed by removing a small brass plug on the body of the BBK regulator and installing the BBK fuel guage into the threaded port. It's Very simple.
In doing research I've found that the the 460 EFI performs best with the fuel pressure set @ 41 to 42 PSI, please refer to the magazine article in my original post.
Ler us know how the install works out.
Will that same regulator work on my 1990 F250 460?
  #35
Old 10-27-2014, 10:35 PM
cbakker's Avatar
cbakker
cbakker is offline
I have my uninstalled BBK 1706 in front of me and it says it is for the 86-93 5.0, but it is the exact same fuel rail mount as the 460. I just haven't installed it yet. It has the brass plug with it that lesoster talked about. I am installing mine along with my maf swap and setting it at 41P.S.I. to start with.
  #36
Old 02-03-2019, 03:14 PM
landtortise89's Avatar
landtortise89
landtortise89 is offline
Originally Posted by jonbar87
We need a dyno graph!
just curious if anyone has tried running a dual plane manifold with stock edi
  #37
Old 02-04-2019, 08:21 PM
cbakker's Avatar
cbakker
cbakker is offline
I thought the factory intake was dual plane. Been a while since I had it off I guess
  #38
Old 01-10-2020, 02:18 AM
Anthony Fontanez's Avatar
Anthony Fontanez
Anthony Fontanez is offline
Cost
What did this build cost you? Did you do all the labor yourself? I have a 97 I'm wanting to rebuild and this sounds perfect.
fordman153
10-08-2016 11:11 PM
SatinBlack03
Modular V10 (6.8l)
15
10-02-2016 03:10 PM
cts2433
New Member Introductions
07-17-2016 06:42 PM
bl8ckb3ar
32
02-09-2014 03:42 PM
eagle275
11-04-2013 11:16 PM
Quick Reply: 460 EFI Ultimate Build
