I'm talking about the bearing that is held in place by a plastic collar on the end of the steering column. Is anyone reproducing these ? I'm in need on one, but haven't had much luck. Thanks !!!
I'm in need of one, but haven't had much luck.
the Bronco Graveyard part is a replacement for the complete assembly, it replaces the white plastic part and the bearing.
I opted to make my own, using the Ford bearing and aluminum bar stock as I didn't think much of their bearing retention method.
sorry no pics, the truck is in NC an I am in China now
unless you have the fabrication skills and equipment, the B/G is the only option that I found
I copied the plastic part in aluminum and attached it with screws through the column tube into the aluminum hub/bearing retainer
if I remember correctly, the plastic retainer had tabs that snapped into holes in the column tube, those were the holes I used for the screws to retain the hub I made
this was over a year ago and I remember that there was no Ford replacement parts then
Do you happen to remember what bearing this was you used? I know it's been awhile since the post. Thanks!
