Hydroboost conversion...
#76
The link I put up says part # E8TZ-2005-B and the part # I bought off of craig's list is
2CZ3-2005-BB. Now another guy told me the first part # is for a 88 year. The second part # is for a 99 thru 04 F250 & F350. Some of those links, to me, sounds like horror stories. I want the direct bolt on that some talk about, I don't have time for shims, grinding, etc.
#80
Digging up old dirt. I just did my hydro boost and I'm less than impressed with my brakes. The pedal is way hard. And looking at the arm that connects to the pedal is at a weird angle. Doesn't seem right. I used all 97 f super duty parts. I know the rod can be rotated 180 degrees. One way the nylon pieces fit right. The other way, the outer nylon piece doesn't fit but the rod is higher and more in line with the hydro unit.
#81
The SD brake pedal is obsolete and you need to either get a SD hydroboost brake pedal from a junkyard or move the pin location on your existing pedal. Just responding to this now so that anyone else considering the hydroboost upgrade that hasn't read other threads will know about the brake pedal difference.
Bob
#82
#83
Cruiseomatic
11-19-2016 05:33 PM
0500757Arf
10-15-2016 09:08 PM
jrodimus
03-29-2016 09:30 AM
boost, conversion, conversions, diesel, f150, f350, ford, hydro, hydroboost, obs, truck, trucks, upgrade, van, whats
