oil sending unit.
oil sending unit.
ok im trying to get my gages to work and im starting with my oil light. i have a 59 f100 292. were is the oil sending unit i cant find it i looked in my manual and it said it should be in front of my oil filter but i cant find it. i found the wire i think. and is my tempature sending unit on my intake manifold in the back left.
I think so (old memory), on a gauge unit the sender uses a variable pyrometer (resistor) [not sure of the terminology, so I just made that up!! ] in the sender unit so as to tell the gauge what to read (show), like a gas gauge, in a light it’s just a spring loaded (pre-set) off or on switch, right? USUALLY the gauge sender as big and fat (like me) and the light senders are smaller.
Normally they are located near the oil filter or on the oil filter mounting ring. It should be about 3/4 to 1" in diameter and about 1 to 1 1/4 inches tall, and shaped a little like a bell or an upside down dixie cup. It will have a little pin sticking out of th etop of it that a wire clips onto. On the block (flat) side it will have a threaded shaft about 3/8 inch in diameter with fine threads.
I'll see if I can find a picture of the one I have.
Edit Note: This one is off a 239 and is more "squat" than most, but they are basically the same-yours may be a little skinnier and taller.
mavman4
11-19-2019 04:03 PM
jschluter
07-20-2015 08:23 AM
Tioga 24
06-02-2002 06:48 PM
