rear end specs? and others
on the axle of your van there will be a tag attached to the one of the bolts. it should have some numbers on it like 3 55, 3 73, or 3 55 LS.
these indicate your axle ratio. you could also google search and use the axle code found on the door jamb and find what you are looking for.
this post may be in the wrong forum. this may help tho.
