rear end specs? and others
Old 09-03-2009, 07:35 AM
readyakira's Avatar
readyakira
readyakira is offline
I have a 2001 e150van and I need to know the rear end ratio. I am trying to have a cam designed for my van that will be used for towing and pleasure...
Old 09-03-2009, 12:33 PM
papajoemrt's Avatar
papajoemrt
papajoemrt is offline
on the axle of your van there will be a tag attached to the one of the bolts. it should have some numbers on it like 3 55, 3 73, or 3 55 LS.
these indicate your axle ratio. you could also google search and use the axle code found on the door jamb and find what you are looking for.
this post may be in the wrong forum. this may help tho.
Old 09-03-2009, 05:25 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
