turn signal switch wiring
Old 08-30-2009, 09:20 AM
RodB-53's Avatar
RodB-53
RodB-53 is offline
need help...putting factory t-signal switch in my '53 f-100.I need a wiring diagram or some one to tell me what color wires go where............................Thanks Rod
Old 08-30-2009, 10:39 AM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
I don't have a wiring diagram for the column switch. Your best bet is to look in your shop manual......Don't have a shop manual? E-bay has about 5 of them for sale for 53s at the moment.
If this is an aftermarket switch that clamps to the column I have a diagram for the 7 wire variety I'll be happy to post.
If your truck was not originally equiped with signals, you are probably going to have to change out your parking and tail light lamp bulb holders and use a two wire/base grounded type instead of the two wire, wire gounded type. I'm not sure when the "Effies" switched to incorporated (not add on) signals.
Welcome to FTE by the way!
Old 08-31-2009, 07:56 AM
fking1's Avatar
fking1
fking1 is offline
If you don't mind waiting a day or 2, I will scan the one I have and post it.
Without it I would have been lost wiring my 55's signals.
Old 08-31-2009, 09:38 PM
RodB-53's Avatar
RodB-53
RodB-53 is offline
turn signal wiring
<P>fking1,I can wait a couple days.I have a 53 shop manual,but they didn't have&nbsp;turn-signals thus no diagram! I am using a 54-6? switch.....................thanks for the help,Rod</P>
Old 08-31-2009, 10:30 PM
Julies Cool F1
Originally Posted by RodB-53
fking1,I can wait a couple days.I have a 53 shop manual,but they didn't have turn-signals thus no diagram! I am using a 54-6? switch.....................thanks for the help,Rod
I asked before but maybe you missed it, but is this a stock switch that is built into the hub under the steering wheel, or is it an external switch that is clamped to the steering column?
Old 09-01-2009, 05:14 AM
merten's Avatar
merten
merten is offline
Go to Mid Fiftys, they have instructions for the stock switch. http://www.midfifty.com/instru.htm
Old 09-01-2009, 05:53 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Stock switch? Which one is that?
Since turn signals were an option back then, the problem is...
There were TWO different turn signal switches used on 1953/55 trucks.
Factory installed and dealer installed. They are not the same.
Western Auto, Sears and autoparts stores sold a similar switch as the Ford dealer installed switch, which clamped on the steering column.
1949/59 Ford Passenger Car Parts Catalog: Illustration Section 130, page 402 shows the factory installed switch for 1953/54 Ford cars. Page 403 = 1955 Ford (not Bird).
These are the same two switches that were factory installed in 1953/55 trucks. Fit inside the steering column.
Old 09-01-2009, 09:12 AM
fking1's Avatar
fking1
fking1 is offline
Use the Mid-Ffity's instructions in the post below. My diagram is about the same , but, is too big to scan on one sheet, needing 2.
Old 09-06-2009, 01:32 AM
t900enforcer's Avatar
t900enforcer
t900enforcer is offline
I have a turn signal wiring diagram for my 55 that I have posted in my gallery.
T900
Old 09-06-2009, 04:51 AM
RodB-53's Avatar
RodB-53
RodB-53 is offline
turn-signal switch wiring
Thanks Guys,went to Mid-Fiftys site and found what I needed to know...........I'll be ready to blink today!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks again Rod.
Old 10-10-2011, 06:50 PM
das54's Avatar
das54
das54 is offline
Thanks guys, just what I needed. I know this is 2 years old but it's still very helpful.
STEVE1103
Electrical Systems/Wiring
03-26-2017 01:19 PM
Narwhal
06-08-2016 03:17 PM
meporsche
1999 to 2016 Super Duty
04-03-2016 04:05 PM
geggleston
11-25-2015 08:26 PM
Fran loves Fords
10-08-2015 09:04 AM
Quick Reply: turn signal switch wiring
