DTC Code #327
Old 08-26-2009, 04:24 PM
Gerald Andre's Avatar
Gerald Andre
Gerald Andre is offline
DTC Code #327
I have a 1993 2.3L Ford Ranger XLT.
When I turn on my ignition, the RPM's accelerate up to 3000-4000 without having to press on the accelerator. They remain at that RPM during the idle.
I have run the KOEO check light test and the following code was retrieved:
#327 - EGR valve position circuit below minimum voltage
Where should I now concentrate my attention?
I have cleaned the MAF sensor with electrical cleaner and that has not corrected the problem.
I am now looking at replacing the EGR Vacuum Regulator (EVR) Solenoid. Anyone else have this problem before?
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old 08-26-2009, 07:20 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
A code 327 usually means a bad DPFE sensor.
GirouxBodyShop
2004 - 2008 F150
13
12-20-2022 10:17 AM
AndeyHall
11-23-2010 09:18 AM
patrickke
07-22-2010 06:18 AM
maxtruck00
18
06-08-2010 09:38 PM
Offroadracer426
03-09-2010 07:45 AM
Quick Reply: DTC Code #327
