When I turn on my ignition, the RPM's accelerate up to 3000-4000 without having to press on the accelerator. They remain at that RPM during the idle.
I have run the KOEO check light test and the following code was retrieved:
#327 - EGR valve position circuit below minimum voltage
Where should I now concentrate my attention?
I have cleaned the MAF sensor with electrical cleaner and that has not corrected the problem.
I am now looking at replacing the EGR Vacuum Regulator (EVR) Solenoid. Anyone else have this problem before?
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
