ABS code C1145
it appears you have the right code for the right front ABS. When you turn on the key, the ABS light should come on, then go off. That means all the wires are connected and the ABS sensor has a complete circuilt. You put in gear and start moving. Once you get to about 10 mph the computer checks and compares the wheel speeds. If the light comes on now, when running over 10 MPH, then the sensor is not reading the gear teeth as they pass.... If the light is on all the time, you dont have good connections. Look in the wire plug behind the head light where the sensor wire plugs into the harness. Are the pins inside the plug mashed and not going into the plug holes?
DTC Description Perform Test B1342 ECU Defective (1)
C1095/C1096 ABS Hydraulic Pump Motor Circuit Failure (2)
C1115 Internal Power Relay (2)
C1145 Right Front ABS Sensor (Electrical/Static) (2)
C1148/C1234 Right Front ABS Sensor (Dynamic) (2)
C1155 Left Front ABS Sensor (Electrical/Static) (2)
C1158/C1233 Left Front ABS Sensor (Dynamic) (2)
C1169 Excessive Dump Time (2)
C1184 ABS System Inoperative (2)
C1185 Open Internal Power Relay (2)
C1194/C1196 Left Front Dump valve (2)
C1198/C1200 Left Front Isolation Valve (2)
C1202/C1204 Rear Dump Valve (2) C1206/C1208 Rear Isolation Valve (2) C1210/C1212 Right Front Dump Valve (2)
C1214/C1216 Right Front Isolation Valve (2)
C1220 Yellow ABS Warning Indicator Failure (2)
C1222 Wheel Speed Error (Dynamic) (2)
C1229/C1237 Rear ABS Sensor (Dynamic) (2)
C1230 Rear ABS Sensor (Electrical/Static) (2)
James Whitaker
04-04-2015 10:04 PM
pjnadon
12-19-2010 10:58 AM
