Under floor brake booster
Brake Boosters.....
[quote=Rarerat;7843310]Has anyone used one of these set ups?
http://cgi.ebay.com/ebaymotors/1953-54-55-56-FORD-TRUCK-UNDER-FLOOR-BRAKE-BOOSTER-F1_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhas hZitem20acd5c904Q
With the excellent Bendix self energizing brakes on the 53 and later
F-100 and F250s there is no brake booster needed. With disc brakes with a little engineering there is also no brake booster needed. I made a post with links to a "Hot Rod Heaven" web site which shows you how to do it on an underfloor system. Check my earlier posts from up to two years ago. That is the way I and many hot rodders do our disk brakes. The only reason I have to use disk brakes on my last build, a '53 F-250 4 x 4 is because the front axle has disks on it. It is a '77 Ford Dana 44 High Pinion front axle with cross steering. Oh, I might add that a 6" booster which is about the largest size that will fit under floor is too small for a standard disk master cylinder unless the piston size has been reduced in the disk portion to below 1" diameter. If you do an underfloor brake booster, make sure it is from Stainless teel Brakes or bought from Mid Fifties in AZ where the owner can give you help himself.
Regards,
Alanco
Regards,
Alanco
Orange '63
05-26-2009 09:47 AM
