clutch hard to push down
Old 08-14-2009, 08:00 PM
ford1puller's Avatar
ford1puller
ford1puller is offline
i have a 1987 f150 302 4speed manual. when i push the clutch down it dosent get easier when its on the floor. the truck drives and shifts ok but i think it could be beter. it feels like pushing the brake down. today i sat in a f150 just like mine and pushed that clutch down and it got to a point and it felt like a spring lol
idk if there is any ajustments or pressure plate is bad or what.
what do you guys think
thanks
Old 08-14-2009, 08:07 PM
amish77's Avatar
amish77
amish77 is offline
Is there a notable difference between when you first push on the clutch and when you engage the pressure plate? Do you remember this being any different when you were driving the other truck?
Old 08-14-2009, 08:26 PM
ford1puller
the other truck dosent run but they said it had a new clutch. its hard to discribe u know how u push a clutch down and its hard at first to push and then it drops to the floor. mine dosent drop u have to push it all the way.
Old 08-15-2009, 04:06 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
Could be a bad pressure plate. However on these trucks there is a cunningly designed pedal spring. With the pedal returning from about half way down the spring helps it to come fully up but when you push the pedal down from half way the spring then helps the pedal go on down.
So first thing to do is check the pedal spring.
Old 08-15-2009, 03:44 PM
ford1puller
thanks ill look into that
that makes sense cuz i dont feel any spring asistance when i push the pedel down
Old 08-15-2009, 04:31 PM
framerboy's Avatar
framerboy
framerboy is offline
I had an 1987 f150 with a similar problem, it turned out that the firewall was flexing when I pushed the clutch pedal. At the time Ford made a reinforcement plate to take care of this problem, we installed it and all was well. I finally sold that little gem with almost 300,000 miles on it. Try
searching the forums for firewall flexing, there is a lot of info on this problem.
Old 08-15-2009, 11:55 PM
ford1puller
when i first got it i checked were the slave cylinder was and the whole plate was moving put a big washer in one of the studs and it got beter. i still think the fire was plat is moving i dont like how ford made that
where did u get ur reinforced plate?
thanks
Old 08-16-2009, 07:40 PM
framerboy's Avatar
framerboy
I had it done in 1996 when the truck had 140,000 miles on it. It was a Ford only part and I bought it at my local Ford dealer, and had my mechanic install it. I would call a dealer and see if they still sell this part.
fifty-two_f1
1999 to 2016 Super Duty
10-14-2021 08:48 PM
Carolina_FoMoCo
08-20-2016 01:37 PM
joegeds
03-31-2015 03:20 PM
RayFord88f150
08-17-2011 03:36 PM
Zerojunk
12-08-2009 02:09 PM
Quick Reply: clutch hard to push down
