Transmission Code HELP!!!
Hey all came out of work this evening and the Excursion would hardly move. It ran fine when I drove it to work. I got it towed home and ran the codes from my auto x ray and found the following codes.
2001 Excursion 6.8 4x4
P0743 Torque Converter clutch cir.
P0755 Shift solenoid B Malfunction
PO1747 Electronic pressure control solenoid short circuit.
The overdrive light is also flashing. When I pull it down in 1st it will move a little better. Will hardly move under its own power. Is there a fix for this or is my tranny toast.
Thanks
Brian Felts
Thanks
Brian Felts
