Wheel Offseet and Backspace - data gurus?
Hello,
Ref Vehicle: 1985 F250, Dana 44HD, 4WD. VIN: 1FTHF26L9FPB20202
This could be a tough one, hope someone can assist.
I am currently overseas and would like to purchase new wheels so they were there when I arrived at home. Could some data guru help me out with figuring out what the OEM Offset and Backspace is so I can order the correct wheels ……or what Offset/backspace I need for the new tires? Also will need the diameter of the hub opening I would need to accommodate the manual locking hubs.
New Tire specs: LT285/75R16 Approved Rim width: 7.5 – 9in, Measured Rim width: 8in, Section width: 11.65in, Overall diameter: 32.9in,
Tires presently on vehicle: 33x12.50R16.5 Specs: Approved rim width: 8.25– 10.5in, Section width: 12.4in, Overall Diameter: 32.6in
The factory original tires (data from window sticker) were: LT235/85R16. From the door sticker: Rims 16 x 6
The Lug pattern is 8 x 6.5.
I would like wheels as close to the original OEM specifications as possible as from what I’ve read this is what is optimized for best bearing wear and ride balance. Can anyone advise as to what offset and backspace rims I would need along with the diameter of the center hub opening .
Thanks in advance.
Rgds
nonrev
Thanks in advance.
Rgds
nonrev
Further research still not turning up OEM offset and backspace but I did finally identify some Ford P/N for the wheels. If anyone out there can provide any info regarding offset and /or backspace on these Ford wheels I would really appreciate it. I’ve torn up Google search and haven’t found anything
E5TZ1015H, E5TZ1015B, E5UZ1015B, E3TZ1015S
thanks
nonrev
thanks
nonrev
nonrev321
09-15-2012 03:49 PM
'49 F3
03-18-2009 07:19 AM
nitronigs
03-11-2008 04:36 PM
