Key Ignition Replacement
Old 08-02-2009, 01:11 AM
jeff9942's Avatar
jeff9942
jeff9942 is offline
1994 F150 XLT 351 cid
What is the trick to changing the ignition switch on the steering column?
Old 08-02-2009, 04:09 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
Do you mean the ign switch lock barrel with the key or do you mean the electrical ign/start switch?
Old 08-02-2009, 09:49 AM
jeff9942's Avatar
jeff9942
jeff9942 is offline
switch lock barrel
Old 08-02-2009, 10:13 AM
quicklook2's Avatar
quicklook2
quicklook2 is offline
turn key to run, stick 1/8" drill in hole below the cylinder, remove cylinder, put in new cylinder.
Old 08-02-2009, 10:18 AM
jeff9942's Avatar
jeff9942
jeff9942 is offline
well that sounds like an easy trick
Thanks quick
Old 08-02-2009, 10:23 AM
quicklook2's Avatar
quicklook2
if you want one key then go to a locksmith and they can key the new cylinder to match your door key.
should be around 40 bucks or so.
the hole is on the bottom of the column and accessed through the plastic below the key.
westend
1999 to 2016 Super Duty
02-14-2018 12:32 PM
Randy Ellenburg
05-11-2017 08:44 AM
mcmain
Aftermarket Products
11-07-2016 03:33 PM
shotgun64
08-26-2015 05:14 AM
Rick_Fury
12-10-2011 10:51 AM
Quick Reply: Key Ignition Replacement
