Key Ignition Replacement
Old Aug 2, 2009 | 01:11 AM
jeff9942's Avatar
jeff9942
1994 F150 XLT 351 cid
What is the trick to changing the ignition switch on the steering column?
Old Aug 2, 2009 | 04:09 AM
Lazy K's Avatar
Lazy K
Do you mean the ign switch lock barrel with the key or do you mean the electrical ign/start switch?
Old Aug 2, 2009 | 09:49 AM
jeff9942's Avatar
jeff9942
switch lock barrel
Old Aug 2, 2009 | 10:13 AM
quicklook2's Avatar
quicklook2
turn key to run, stick 1/8" drill in hole below the cylinder, remove cylinder, put in new cylinder.
Old Aug 2, 2009 | 10:18 AM
jeff9942's Avatar
jeff9942
well that sounds like an easy trick
Thanks quick
Old Aug 2, 2009 | 10:23 AM
quicklook2's Avatar
quicklook2
if you want one key then go to a locksmith and they can key the new cylinder to match your door key.
should be around 40 bucks or so.
the hole is on the bottom of the column and accessed through the plastic below the key.
westend
Feb 14, 2018 12:32 PM
Randy Ellenburg
May 11, 2017 08:44 AM
mcmain
Aftermarket Products
Nov 7, 2016 03:33 PM
shotgun64
Aug 26, 2015 05:14 AM
Rick_Fury
Dec 10, 2011 10:51 AM
