2005 F150 radio remove
I could be wrong but cd players since the mid 90s have been able to read and play writeable discs. I think if a player is labeled mp3 then it is capable of running an auxilary source through the system such as an ipod or mp3. If I am off base someone let me know. I have not installed the shaker yet because i only want to do it once. Thanks
What I think you're after is an Auxiliary input for MP3 players, DVD players, etc. If your stereo has a button on it that says Aux, then you have options in that regard. Does it?
Then I believe one of these is what you are looking for.
PIE Adapters
They add the capability to plug your MP3 player directly into your radio and in some cases even control playback through it. Playback control is dependent on your MP3 player being compatible, if it isn't, then you'll just have to control it on your player instead of the radio controls.
PIE Adapters
If your head unit has "MP3" labeled on the front of it, that ONLY means you can play an MP3 formatted cd. It has nothing to do with weather or not you can add an input to plug your MP3 player into your head unit........
GGerald
05-18-2020 04:50 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
08-03-2016 08:37 AM
Kalve
18
03-28-2011 11:55 PM
