Anybody ever hear about a spark plug disintegrating and falling into the engine?
This is a work truck, but I have never heard of this one - and a search yielded no information.
A co-workers 2006 Ford F150 (4.6 or 5.4, unsure of which one) with 58,000 miles, crew cab, auto. The truck had a loud noise/quit running. The mechanic's diagnosis is that a spark plug end disintegrated and fell into the engine - damaged the piston and bent the valves. I've heard of them blowing out, but falling in??
It's a company truck that had the oil changed every 3 months/3,000 miles.
I'm very happy with my '08 F250 SD 5.4 so far, but I'm concerned. Is there a problem with Ford spark plugs, or is this a one in a million deal??
Since most of the plugs are "2-piece" (including OEM). It could be possible. Normally people have an issue extracting the plugs somtimes resulting in pieces falling in.
Here's a recent thread in this forum with some links to go back to for reference.
https://www.ford-trucks.com/forums/8...ark-plugs.html
Its prevalent with the 5.4L
And...actually it being 2 pieces couldn't be the culprit here unless the plug was defective, as the lower piece can't actually slide down into the cylinder because of the taper on it.....The only part that could have potentially came apart would have been the ceramic, but thats highly unlikely since the ground strap at the bottom would have prevented it from falling inward.....
Its got to have been a defective plug.....in my opinion anyhow
Wow, what an eye opener!
I just read through some of those old threads on the plug problems in the 3v 5.4's, scary stuff! I remember many years ago I found a good deal on a Suzuki Sidekick 4 door (under 10k new), and at 30k I tried to change the spark plugs. They were "welded" to the head, and pulled the soft aluminum out when I tried to change them. Suzuki eventually (had to call their 800 #) paid to fix it (heli-coil) and they later told me that the factory had over torqued them on the assembly line!
It looks like I lucked out with my SD, that sometime in 2007 Ford re-designed the heads to take conventional plugs - so my late 2008 build '08 SD with the 5.4 3v should not have this issue.
I know my co-worker was driving the '06 F150 it when the plug gave away, I guess it was a fluke....
HYPO
Sounds to me someone may have over torqued that spark plug. The threaded sleve on the plug can crack, split in half and then fall into the cylinder or the electrode can come apart and fall into the cylinder too. The threaded taper on the plug is actually nothing more than a pipe thread. I only ever seen a plug desinegrate a couple times when I worked at a GM dealership as a tech, but fortunately its rare. If the installer follows the factory torque specs, stuff like this won't usually happen. Just my $.02 worth!
Jim
Jim
Yep...plugs changed...i posted a picture on here not too long ago...but i don't remember the thread
My engine build date is 08-05-2008...
according to the sticker on my valve cover. It makes sense, my truck has a 09-2008 build date on the door jamb sticker.
I got "lucky" with my leftover '08, in that it was a very late build. I think I read somewhere that that slowed production down due to the fact that they could not move the '08's, and extended '08 production a few months. I bought mine in mid-February, so it probably only sat on the lot around 4 months. I test drove a Nissan Titan (at the same) that was built in November '07 (and was not a demo), 15 months on the lot!
I'm very happy with it so far, but I only have 3,500 miles. It's very tight and is quieter than both my cars on the road and the 5.4/3.73 has been adequate with my modest tow needs. I'm usually a manual tranny guy (all my other vehicles are manual shift), but I'm impressed with the TS 5 speed so far - I really think it's way overbuilt for the 5.4, which should mean I'll (hopefully) never have tranny problems. The tow/haul mode works really well to wring the most out of the 5.4 as well. I received a great deal on mine, but I would have taken it with the ZF stick at the same price truth be told...
Thanks for all the input, this is a great site.
Amish Ford
07-18-2016 01:54 PM
nathankershaw
06-27-2016 08:32 PM
