1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Air bag code
Old 07-23-2009, 08:42 AM
ralphcri1's Avatar
ralphcri1
ralphcri1 is offline
Air bag code
I have a 2004 expedition flashing code 42. found out code means driverside crash sensor mounting fault. Where is this sensor?
Old 07-23-2009, 10:04 AM
alloro's Avatar
alloro
alloro is online now
Received 4,196 Likes on 2,432 Posts
You should find it down behind the front bumper, driver's side. This code usually means that ground has been lost at the sensor. Perhaps the bracket has rust and just needs a bit of cleaning.
Old 07-23-2009, 10:46 AM
ralphcri1's Avatar
ralphcri1
Thank you i will look at that.
Old 07-24-2009, 11:15 AM
ALLDATAdiy INFO's Avatar
ALLDATAdiy INFO
ALLDATAdiy INFO is offline
Former Vendor
If that doesn't fix your problem, you may want to look into an ALLDATAdiy.com subscription. There is a ton of info on the Code 42 for your Ford. There are 54 test steps to go through to help isolate the problem within the entire circuit. I attached an image directly from ALLDATAdiy.com showing you where the sensor is.
thunderbird1986
10-21-2013 07:30 AM
graeaglecrawler
11-18-2011 02:10 PM
loudford
1999 to 2016 Super Duty
13
11-12-2009 06:25 AM
winter123
1997 - 2003 F150
09-27-2009 07:50 AM
beefster
05-24-2006 05:06 AM
Quick Reply: Air bag code
