Air bag code
Old Jul 23, 2009 | 08:42 AM
ralphcri1's Avatar
ralphcri1
Air bag code
I have a 2004 expedition flashing code 42. found out code means driverside crash sensor mounting fault. Where is this sensor?
Old Jul 23, 2009 | 10:04 AM
alloro's Avatar
alloro
You should find it down behind the front bumper, driver's side. This code usually means that ground has been lost at the sensor. Perhaps the bracket has rust and just needs a bit of cleaning.
Old Jul 23, 2009 | 10:46 AM
ralphcri1's Avatar
ralphcri1
Thank you i will look at that.
Old Jul 24, 2009 | 11:15 AM
ALLDATAdiy INFO's Avatar
ALLDATAdiy INFO
Former Vendor
If that doesn't fix your problem, you may want to look into an ALLDATAdiy.com subscription. There is a ton of info on the Code 42 for your Ford. There are 54 test steps to go through to help isolate the problem within the entire circuit. I attached an image directly from ALLDATAdiy.com showing you where the sensor is.
thunderbird1986
Oct 21, 2013 07:30 AM
graeaglecrawler
Nov 18, 2011 02:10 PM
loudford
Nov 12, 2009 06:25 AM
winter123
1997 - 2003 F150
Sep 27, 2009 07:50 AM
beefster
May 24, 2006 05:06 AM
