53 250 leaf springs
on
Here's something I saved from a previous post that might help:
Recommendations in the Mid-Fifty catalog. "Starting with the shortest, keep #1, remove #2, keep #3, remove #4, keep #5, remove #6, keep #7 but cut off the wrap 1 1/2" from the eye. " With reversed eye springs this is supposed to drop the rear 3 to 3 1/2".
Assuming that you followed the above or something similar, it would depend on what you want and how the truck feels now.
If the ride is already soft, I would remove the short one to drop it a little more but maintain as many long springs as possible.
If the ride is still too firm, I would look at removing one of the longer ones as this will tend to soften the ride. I would not remove the spring immediately under the main spring (#7 above).
For F-1 springs you keep the shortest and take out #2, #4, and #6. I suppose with the F-2 you could take out #8 and #10 too. If you do not plan to carry anything heavy in the bed...maybe even more. The minimum number of leaves left should be about four. My F-3 had 13 but I used different springs.
bigboisteiny
07-30-2014 04:41 PM
octaneforce
05-04-2010 09:50 PM
