PO 775 code
Old 05-19-2009, 09:45 PM
dsljay's Avatar
dsljay
dsljay is offline
PO 775 code
My wife got a check tranny light followed by the OD shutting off. Then she got a check engine light. She stopped at the parts store and they read the code. It is PO775 "pressure control solenoid B circuit malfunction" . Anyone else have this problem and what is the fix?
Old 05-19-2009, 09:49 PM
dsljay's Avatar
dsljay
dsljay is offline
Sorry, it's a 2002 merc Mountianeer, auto with a 6 cyc.
Old 05-21-2009, 11:43 AM
jk080's Avatar
jk080
jk080 is offline
Transmission Rebuilder
That code is indicating a mechanical problem with a solenoid. I would replace the solenoid block. I have not ran across that code before but I do know that those solenoid blocks have problems, I have replaced many of them for a number of issues.
Old 05-21-2009, 04:22 PM
dsljay's Avatar
dsljay
dsljay is offline
Thanks, jk080. Do you where the soleniod block is located on this car?
Thanks again, Jay
Old 06-15-2009, 11:25 PM
dsljay's Avatar
dsljay
dsljay is offline
update
Bad result. The trans needed to be rebuilt. $2100. at an indy garage. The dealer wanted 3500.
landscapeguy
6.2L V8
06-04-2017 01:36 AM
Wendy Rouleau
04-24-2017 09:35 PM
tomeug69
12-10-2015 08:48 PM
WINGNUT-
1997 - 2003 F150
06-24-2014 04:30 PM
robin1t2002
1997 - 2003 F150
04-23-2012 10:29 AM
Quick Reply: PO 775 code
