Can I use RTV on C-6 pan gasket?
I've got a small leak from the transmission pan gasket and its dripping fluid on the exhaust.
I've been under the truck re-torqueing the bolts hoping that the leak stops. No joy. The level is ok.
I bought a new Fel-Pro gasket (rubberized gasket) and the instructions say not to use any sealant with this gasket. The Haynes Manual says to use some RTV on it.
What is correct?
What is correct?
Like the guy said, make sure the surfaces are clean. Also no oily residue, use something that will leave the surfaces totally dry and not slippery. I use brake cleaner or some gun scrubber stuff.
Also make sure the srufaces are smooth and flat. Check the surface of the oil pan. Sometimes the bolts will cause the surface of the pan to dimple and may cause a leak unless flattened out. I use a small peen hammer or a flat punch to gently flatten the surface out.
RTV can be used but it all depends on WHAT KIND. Some work but most will swell and get loose in contact with oil. Been there done that. Use only the CORRECT RTV and only if called for. Doesn't look like it is called for by your gasket maker.
Good Luck,
Jim Henderson
Good Luck,
Jim Henderson
Necromancer
01-25-2016 08:37 PM
cabloom300
11-03-2013 09:52 PM
ManfredVonRichtofen
16
06-23-2012 02:04 PM
ceetwarrior
03-21-2005 11:45 AM
