RTV or No RTV, this is the question.
Old 01-25-2016, 05:06 PM
Necromancer's Avatar
Necromancer
Necromancer is offline
I have a 94 f150 I6, manual. I'm replacing the thermostat with a Motorcraft thermostat and gasket. Do I need a rtv type sealant if the housing is in good shape? I've read a few conflicting write-ups...some say just use the gasket only, some say use rtv with the gasket. Thoughts?
Thanks...
NEC
Old 01-25-2016, 05:42 PM
RIKIL's Avatar
RIKIL
RIKIL is offline
I think it depends on your parts. I have heard some need the RTV because the parts aren't flush. For my truck, I don't need it.
Old 01-25-2016, 05:53 PM
88n94's Avatar
88n94
88n94 is offline
I use the blue colored stuff from permatex on most everything. It doesn't harden so much and should make cleaning up easier if it ever needs attention again. I think it's called RTV, comes in a tube like RTVs. I never had anything leak that I used this on.
Old 01-25-2016, 05:58 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
If your using rtv , why use a gasket? You should not need rtv at the thermostat, but use one or the other, not both.
Old 01-25-2016, 06:01 PM
chrismd188's Avatar
chrismd188
chrismd188 is offline
I always use the blue silicone,put a VERY light coat on both sides of gasket.
Never had leaks that way
Old 01-25-2016, 06:04 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Agreed. If anything, hi-tack to hold the gasket in place
Old 01-25-2016, 06:47 PM
animator's Avatar
animator
animator is offline
The gasket should have a sticky side to help hold it in place. I didn't use anything other than the gasket, and do not have any leaks.
Old 01-25-2016, 07:17 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
Never seen a thermostat gasket have a sticky side, not saying they don't make them. It should not be hard to hold the gasket in place, push the bolts thru the housing, slide the gasket over the bolts and start the bolts. I changed water pump and thermostat on my 4.9 about 5 months ago, no rtv, just gaskets. No leaks yet.
Old 01-25-2016, 07:25 PM
dixie460's Avatar
dixie460
dixie460 is offline
Just take your gasket and smear a light coating of Permatex No. 2 on each side. It's non hardening and tacky enough to hold your gasket in place, and if you have any imperfections in the machined surfaces it'll take care of that for you too.
RTV is for when you don't HAVE a gasket to work with! Or to fill in gaps like in corners of gaskets where they meet other parts.
Old 01-25-2016, 07:27 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
^exactly, using rtv with a gasket actually increases your chance for leakage.
Old 01-25-2016, 08:37 PM
Necromancer
thanks all!!!
copen93
01-24-2015 05:46 PM
obscurity
06-12-2013 09:34 PM
Fordman_Evs
11-05-2006 12:30 AM
wickymustang
01-18-2006 09:19 PM
kinnja
08-18-2004 12:37 PM
Quick Reply: RTV or No RTV, this is the question.
