Air Help?
Old 06-09-2009, 02:22 PM
MikeBrax's Avatar
MikeBrax
MikeBrax is offline
Air Help?
I have a 2006 Lariat 5.4 L F-150 all I have added is a K&N air filter. I don't know that much about upgrading it so I need some help. What kind of Air intake, cold air intake, ram air should I get. I don't know the difference between them which is a better/worse choice for performance & price for me. Any help would be really appreciated.
Thanks.
Brax
Old 06-10-2009, 11:09 AM
Beechkid's Avatar
Beechkid
Beechkid is offline
If you do an online search for “air filter test” there is a lot of very good information. IMHO, the CAI units are NOT WORTH THE $$! Unless you are talking about a system that was specifically designed for a specific application there are very little hp/tq gains actually achieved in a street use vehicle and there are very few docs that these mfg’s can produce that actually show an increase in hp/tq in the power-band range of a relatively stock street vehicle.
I would avoid oil impregnated filters. While they have their purpose in off-road applications, Ford/GM/Dodge all have “watch-out” bulletins where the oil has contaminated intake sensors. - they even have a training video for the tech's on this (flatratetech.com) .
If you look at the flow data, WIX HP filters flow 98+% of K&N and have a much smoother flow post filter plus excellent filtering, for a fraction of the price! The OE’s have an excellent air intake system the only issue that really exists is the plastic intake tube with it’s noise canceling design- that does reduce the intake efficiency a little but makes it very quiet!. You can use a WIX OEM HP replacement filter in the OEM plastic manifold box and either remove the plastic tube and replace it with a piece of pipe/hose, etc or remove the tube completely and replace the tube by building an air ram type intake into the air box manifold (where the pipe use to attach)- make sure ti terminates above the fan shroud to avoid water intake or fan induced pulsations.
Beechkid's Avatar
Beechkid
Beechkid is offline
reply
Old 06-12-2009, 03:37 PM
MikeBrax's Avatar
MikeBrax
MikeBrax is offline
I was thinking about either going with Banks or K&N for my cold air induction. Is ine better than the other in your guys opinions. I don't know much about fixing up trucks, but want to pimp mine out a little. Any info is much appreciated.
BadAzzFordF250
1999 to 2016 Super Duty
24
03-14-2023 03:55 PM
pukemon
Aftermarket Products
30
08-08-2016 12:47 PM
zloomis
04-08-2015 10:46 AM
Sleep
1997 - 2003 F150
01-18-2015 06:02 PM
7.3RP
1983 - 2012 Ranger & B-Series
02-20-2014 07:31 PM
Quick Reply: Air Help?
