1987 Ford 2.9L Idle Problems
My truck is idling funny when it has sit overnight and i crank it up in the mornings. It will go up to 2000 rpm's then come down to 1000 rpm's then eventually shut off. After i crank it back up it goes back to 1000 rpm's and settles. Usually it runs pretty good after that. I cleaned the throttle body and put a new idle air control valve on but still the same problem.
On the upper intake plenum, left center, you will see a round canister with a wire sticking out of it, bolted into the manifold. This your idle air control valve or IAC. They often get gummed up and cause poor idle. Take it off, and really soak it down with your favorite parts/carb/brake cleaner. That can cause an erratic idle like you describe.
EDIT: Just saw you already tried that, disregard above.
How does it eventually shut off? RPMs gradually drop lower and lower until it dies, sputters to a halt, or just cuts straight out?
I have a similar problem on my 88 2.3l. Mine does the same thing on a cold start, but usually doesn't stall. It does seem to idle fast after warmed up. About 1400-1500rpm.
I am going to try and clean the IAC. Sounds like a good start. Also just bought it so probably need to check all the tune-up items.
Allen
Allen
jrgrtx
07-26-2017 05:06 PM
