Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch, Transmission, Differential, Axle & Transfer Case
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-22-2002, 07:49 PM
canadianfordman canadianfordman is offline
Garage is empty, add now
canadianfordman is starting off with a positive reputation.
C6 for 351 cleveland
I have a 351 cleveland and I want to bolt a C6 up to it. Is there a difference between small block C6's and big block C6's? I have a chance at a few but they were both previously bolted to big blocks. Thanks
__________________
2007 F350 C/C XLT 6.0 4x4
2005 F150 Super Crew Lariat 4x4
1984 F150 XLT 351w and C6 is Chromed to the Nutz!
  #2 (permalink)
Old 04-23-2002, 10:21 AM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
CanadaMike, there are 3 differant cases that I have seen so far, first the FE case, the the 385 series case, and then the 6 cyl and small block. The internals are largely the same. I haven't seen a C6 behind a 351C in a factory application, but the local salvage yards here have lots of them behind 300 inline 6s, which would bolt to your 351C just fine. Look in full size 2wd trucks and vans. DF
  #3 (permalink)
Old 04-23-2002, 11:48 AM
Fordknut Fordknut is offline
Fordknut is starting off with a positive reputation.
I think all the 4Bbl Clevelands with ATs had C-6s mounted to them. I have a C-6 that was factory mated to a 2Bbl Cleveland in a Cougar; '72, I think. Small block C6s are somewhat scarce, but not what I'd call rare. Check out the local wrecking yards and attend a few swap meets; you should be able to find one. I'd sell mine, but I wouldn't want to go thru the hassle of shipping it.
  #4 (permalink)
Old 05-09-2002, 02:06 PM
DavidB DavidB is offline
DavidB is gaining momentum as a positive member of FTE.
There are a lot of sb C6 trannys in salvage yards in vans behind I6 and sb V8 engines. Should not be hard to find one. I have seen many 70 Mustangs with 351C and FMX transmission. So many that I thought this was standard. I have replaced FMXs with sb C6s.
  #5 (permalink)
Old 05-09-2002, 04:35 PM
AZ4x4f150 AZ4x4f150 is offline
AZ4x4f150 is starting off with a positive reputation.
if you are running a 302 or a 351W the bell housings are the same.
If you are running a 351C or a 390 or 460 the bell housings are the same. you can not bolt the C-6 from the 302/351W to a 351C.
But you can interchange the insides from the big and small block C-6's
the torque converts will bolt up in either bell housing.
  #6 (permalink)
Old 05-10-2002, 08:36 AM
"if you are running a 302 or a 351w the bell housings are the same.
If you are running a 351c or a 390 or 460 the bell housings are the same. you can not bolt the C-6 from the 302/351W to a 351c.
But you can interchange the insides from the big and small block C-6's the torque converts will bolt up in either bell housing."
I am having a little problem with the post from AZ4x4f150 above. There are so many different bolt patterns that I sometimes have to stop and think about which ones interchange myself. My recollection is this:
I6,289,302,351W, AND 351C interchange
332, 352, 360, 390, 410,428 interchange
351M, 400, 429, 460 interchange
These engine bolts patterns DO NOT interchange between groups.
I am getting on in years. My memory could be failing. You might want check with others for confirmation.
  #7 (permalink)
Old 05-10-2002, 09:19 AM
sauerf100s sauerf100s is offline
sauerf100s is starting off with a positive reputation.
DavidB, You are almost 100% correct. Some of the earliest 400's had the small block bolt pattern. A friend of mine told me he had one.
__________________
Steve Sauer
  #8 (permalink)
Old 05-10-2002, 05:44 PM
marriedguy1 marriedguy1 is offline
marriedguy1 is starting off with a positive reputation.
__________________
Matt
If you're not suppose to eat animals, why are they made of meat?
Tags
351, 351c, 400m, 460, ac, bellhousing, bolt, bolts, c6, cleveland, drivetrain, interchange, pattern, tranny, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
