what exactly does this code p0320 refer to. Did a search and a few refer to the pip in the dist. or possible the fender mounted ignition module. any thoughts ?'
refer to previous post for symptoms. https://www.ford-trucks.com/forums/8...ing-weird.html
The TFI modules are known for producing this type of failure, replace it but don't use an aftermarket module use only a Ford module and make sure you get one that is the same color as the one you have, they are either grey or black.
i also read on other forums that a 2-way radio signal can mess up the signal from the pip in the dist. is that true? i do have a wireless airbag controller in the truck.
