Rough engine, P0320, P0354, P0355,...
My 2003 Expedition 5.4L with 120K is running very rough between 1K - 2.5K RPM and occasionally displays charging light and stalls when stopped.
Sometimes I get 5 DTC codes: P0320, P0354, P0355, P0356, P0358
- I've purchased 3 COPs, replaced 4,5 and 6 then swapped the rest around, but the P034x numbers stay the same.
- All old COPs read good Ohm values across the two connection pins and between B+ and plug spring.
- I've replace the 14305 wiring harness (per TSB 04149) and the CKP - Crankcase Position Sensor.
- I've cleaned the MAF with MAF cleaner
- I've replace some vacume lines on the top left rear of the engine and they are all sealed now.
Any ideas?
Kevin
Any ideas?
Kevin
nightflight
1997-2006 Expedition & Navigator
03-21-2013 10:57 PM
