GOOD aggressive sound, with lift kit
I have a 1996 F150 4x4. Right now, I have Magnaflow mufflers and tips. I would like to see what would be a more aggressive sonding muffler? POSSIBLY glass packs, Flowmaster super 44?...Deep rumble that can turn heads (loud) when you crack down on it? ALSO.. lift kit wise I have looked at Rough Country 4" suspension kit.I'd like to know how big of tires could I fit with a 4" lift?.opinions on either of these topics?
thanks
thanks
No, 4-6" taller than stock. Your best bet is 315s (35") tires. You can probably get 36"s under it, but you will most likely get some rub out of it. 33" tires should be the recommended height, but the 35"s with a decent offset on the wheels will clear. The lift kit manufacture will have the specs for tire/wheel width and backspacing.
NitrousAl
08-21-2005 06:50 AM
