GOOD aggressive sound, with lift kit
Old 05-23-2009, 12:00 PM
ta-MATER's Avatar
ta-MATER
ta-MATER is offline
I have a 1996 F150 4x4. Right now, I have Magnaflow mufflers and tips. I would like to see what would be a more aggressive sonding muffler? POSSIBLY glass packs, Flowmaster super 44?...Deep rumble that can turn heads (loud) when you crack down on it? ALSO.. lift kit wise I have looked at Rough Country 4" suspension kit.I'd like to know how big of tires could I fit with a 4" lift?.opinions on either of these topics?
thanks
Old 05-25-2009, 11:08 AM
ReAX's Avatar
ReAX
ReAX is offline
If your just looking at mufflers, take a peak at SpinTech muffler's. They are like Flowmaster's Delta 40, but sound deeper and less tinny to me.
With a 4" lift you can fit 4-6" taller tires, maybe 8", but it may cause alot of rubbing.
Old 05-25-2009, 05:42 PM
ta-MATER's Avatar
ta-MATER
ta-MATER is offline
4-6" taller tires as in 4-6" taller than 31's that fit stock ?(i have 31" Firestone tires right now)
Old 05-25-2009, 06:02 PM
ReAX's Avatar
ReAX
ReAX is offline
No, 4-6" taller than stock. Your best bet is 315s (35") tires. You can probably get 36"s under it, but you will most likely get some rub out of it. 33" tires should be the recommended height, but the 35"s with a decent offset on the wheels will clear. The lift kit manufacture will have the specs for tire/wheel width and backspacing.
Old 05-26-2009, 06:16 AM
ta-MATER's Avatar
ta-MATER
ta-MATER is offline
sweet, thanks !
Old 06-04-2009, 01:42 PM
kingkongzilla's Avatar
kingkongzilla
kingkongzilla is offline
I bought a badass lift kit and other <a href="http://www.myhotf150.com/">Ford F150 Accessories</a> from myhotf150.com. Pretty good site.
cajunfuse
6.7L Power Stroke Diesel
17
01-31-2014 10:28 PM
glenerd51
2004 - 2008 F150
05-07-2013 11:03 AM
Atwiss
1999 to 2016 Super Duty
03-03-2010 11:16 PM
NitrousAl
08-21-2005 06:50 AM
Quick Reply: GOOD aggressive sound, with lift kit
