Is there an easy (i.e. cheap) way to change the flasher relay so the turn signals blink faster? I'm able to make my lane change/turn before completing two flashes of the turn signal light!
Battery voltage checks out fine. My signals have been slow for all ten years that I've owned the truck, just now motivated to change it -- maybe it's an HD flasher??
My 96 has two flashers, if yours is the same they are located on the fuse panel inside the cab. One is on the front and the other is directly behind it on the back side of the fuse block. You will need the two prong style flasher. Even if it is a HD flasher it should flash faster than that. As far as pricing the regular flashers are fairly cheap, the hd flashers that I use run around $20 at NAPA.
