AC doesn't feel as cold?
Old May 13, 2009 | 09:23 AM
ghunt's Avatar
ghunt
I ran my AC the other day for pretty much the first time since it's warmed up this year.
It seemed to take a long time to get cold, and on normal AC it didn't feel as cold as I thought it should. I swear it worked better last year.
What do I need to check?
Also would this truck have R12 in it?
Old May 13, 2009 | 09:43 AM
mstngmikegt's Avatar
mstngmikegt
The bad news is you probably have a slight leak in the system. Not surprising given the age of the system. Do a visual check of lines and fittings for oil traces. The good news is that your truck uses R-134a refrigerant (there should be a sticker underhood to confirm this, but '94 was the first year it was used industry wide.) This means that check/recharge at an A/C shop is reasonable compared to R12 (restricted and extremely expensive) or that you can recharge it at home for under $20. Since it blows cool, and you didn't mention the compressor clutch cycling in and out very frequently, it is still mostly charged and getting it cold again should be easy.
Old May 13, 2009 | 07:01 PM
jr32560's Avatar
jr32560
97ExpGuy
Jun 24, 2014 07:01 PM
marks500
Jun 16, 2014 08:52 AM
TG-Digz
Dec 15, 2013 08:10 AM
wulfman
Jun 12, 2011 10:57 PM
soggybottom
Jun 7, 2011 12:47 PM
