British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
power windows
Old 05-22-2009, 08:38 AM
sppinner's Avatar
sppinner
sppinner is offline
power windows
I have a 2003 6l diesel. The windows will work sometimes and then they quit working. Also have had a problem with the backup sensors doing the same thing. They will go for a few days working fine and then they quit. Any ideas would be appreciated.
Old 05-22-2009, 05:16 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
i lost the power to the rite rear window on my 03, turned out it was the master switch on the drivers door...
not sure about the reverse sensor other then maybe trying unplugging them and cleaning the contacts...
Old 05-23-2009, 11:35 AM
Saleenguy's Avatar
Saleenguy
Saleenguy is offline
Just drive it on the days they all work.
Old 05-23-2009, 11:38 AM
Saleenguy's Avatar
Saleenguy
Oaky seriously, intermittent crap is hard to find.
Bad ground?
A relay that is tired, but works on occassion?
If its temp related, it could be something with a poor conduct say when cold, but heat expands it enough to make contact.
A wrire thats worn thru the insualtion, and bumps jar it free and it works, then it goes back to being shorted out.
Could be a million different things really.
I would get a multi meter and start checking wiring and relays to start with.
Old 05-23-2009, 12:23 PM
tin-man's Avatar
tin-man
tin-man is offline
Hello everyone, I would start at the door switch.
ryanhuntter
09-30-2014 09:01 AM
Kevin Thrash
1997 - 2003 F150
12-28-2012 06:55 PM
Jay
06-08-2012 05:10 PM
knabjordan
Aerostar
03-11-2006 12:53 AM
straightshooter
1997 - 2003 F150
12-26-2003 07:19 AM
Quick Reply: power windows
