T-18 Borg Warner Trany + 1955 I-6 223 Engine?
I found a really cheap T-18 Borg Warner Top loader 4-Speed Manual Trany locally, and I was curious if I could make it work on my stock I-6 223 engine in hopes of getting rid of my stock 3-speed heavy duty column shift trany.
I just like the idea of a floor shift trany instead of column shift, but perhaps that is sacrilegious.
The guy says it came out of a 4x4 1970 Ford Bronco, but based on my research, the T-18 trany was used in the 1956 - 1990 Ford trucks. My concern is two fold. First, does it make a difference if it is a 4x4 trany, and will it work on my 1955 2x4 F-250? Second, can I make this trany mate up to my 223 I-6? Or are there better 4-speed manual floor trany choices available that would mate up to my 223 engine better?
Please let me know soon. Thanks.
I have pictures of the trany if you want me to post them up if that would help.
T-18 Truck Transmission
Regards,
Alan
The 223 could be ordered with a Borg Warner T-98 four speed crashbox. The bellhousing is different from the standard 3 speed don't know about the HD 3 speed maybe you lucked out. The T-18 is a later version but if it was behind a 302 I believe the input shaft "stickout" is less than you need plus the 4 x 4 version bolts to a transfer case rather than having a yoke to bolt your driveshaft to. Google Advance Adapters, they make adapters for the 4 x 4 set and have some useful dimensions in some of their PDF files.
T98-t18-t19
Some responses are missing the point:
1. A T-18 4WD model won't work for a 2WD truck, as it is made to mate with a transfer case only, has no tailshaft, would require a new mainshaft and tailshaft.
2. Yes, a 223 came with a T-98 originally if it was ordered that way.
3. A T-18 and its upgrade, the T-19 are better than the T-98 in noise and in shifting, but all are not good transmissions for a 1/2 ton pickup with a 6 cylinder which is going to be used for light hauling or just transport.
4. The friction coefficient of a 4 speed heavy truck transmission was not even mentioned. Just figure what horsepower is required to turn the countershaft, idlers, etc in the 90 weight gear oil as compared to a smaller light transmission. A short time ago, gas was over $4 a gallon. Why would you not want a transmission that was efficient and would save on gas as well as one that would be easy to shift?
Regards,
Alan
Alan,
Thanks for the info. Keep in mind though that my truck has a Dana/Spicer 60 rear end with 4.88 gears, and my truck is an F-250 not a F-100. I am not sure what model trany I have in my stock truck, but I know it is the Heavy Duty 3-Speed that came with it.
Like some other have suggested in the past, I would not only need to swap out the rear end, but the trany as well to get better mileage and highway driveability.
The T-98 is an excellent (& very strong) transmission. .....They are fully supported with rebuild parts etc...
The T98 Transmission - Novak Conversions
Borg Warner T98 : Tellico 4x4
Borg Warner T98 4 Speed repair parts and overhaul kits. - Drivetrain.com
I have a very nice T-98 with tail mounted parking brake, bell housing, new: clutch, pressure plate, pilot and throw-out bearings, that I would be using if I wasn't putting an automatic trans in my F-600. (if someone in the NW is interested! i don't think it would be cost effective to palletize and ship)
If you use synthetic oil in it I would bet you wouldn't be able to tell much difference in mileage between it and any modern (non-OD) trans.
I don't think there are very many people with old trucks on here that do a lot of worrying about gas mileage with these trucks.
They're usually not used as commuter cars. That said, I fully expect 15 mpg or better with my F-600 (when empty of course on a flat freeway!)
Cheers,
Rick
Cheers,
Rick
Alan,
Also, the drag of a T-98 or T-18 is due to the size of the cluster gear running in the oil, and the thickness of the oil itself. More modern transmissions are made to use light oil of 30-40 weight, not 90 weight. It is the oil viscosity, not the slickness or lubrosity of the oil that makes the difference. But the size of the cluster gear and its bearings is a part of the overall parasitic loss of such a large transmission.
If your rear end were regeared to 4.11 and an OD was used, the final drive would be 2.87 in OD. It would be 3.41 with a 4.88. either would be a lot better than what you have now with 1:1 in high gear. I changed my Dana 60 to 4.11 and am using it with a 700R4 Automatic OD which is .70 in overdrive.
Regards,
Alan
If you want to be able to compare gears ratios and tire sizes with RPM, you need to use a gear calculator.
Fatboy Raceworks Graphical Transmission Gear Ratio Calculator
I simply calculated (using the actual tire diameter) how many tire revolutions my tire would make in a mile and calculated it at 60 mph (1 mile per min) which gives me rear tire revs per min.
Then you simply multiply that by your rear ratio and any overdrive (if installed) to get engine RPM (at 60)
Here's a better one http://www.angelfire.com/fl/procrastination/rear.html
That calculator above is simple enough to use. Search around, there's a bunch of them out there. Most will either allow the use of the actual tire size in inches or the tire size in metric standard size etc.
The T -18 is more up to date than the T-98,both are good if not great gear boxes,I dont see why a T-18 would be a bad choice behind your 223.
svspeeder
03-03-2014 01:14 PM
spartan21
03-05-2012 09:04 AM
Glockem45
15
05-12-2009 11:01 AM
