1989 F-150 4 speed manual shifter removal
04-21-2009, 11:34 AM
on
How do you remove the shifter from a 1989
f-150 4 speed manual transmission?
04-21-2009, 09:12 PM
on
on my 89 f250 theres 4 screws on the corners of the rubber matt. i believe there philips screw then lift it up and 2 more screws will take shifter off
04-22-2009, 04:06 PM
on
I have removed the rubber boot. There are 2 little red buttons on the shifter that push in. They must hold the shifter somehow.
04-22-2009, 07:45 PM
on
There should be two screws in the top.. the buttons that pull out are guides in a way.
04-22-2009, 07:56 PM
on
The red buttons are inside a hole in the square part of the shifter that attaches to the round shift rod coming out of the transmission. They will not pull out, only push in.
04-22-2009, 08:58 PM
on
I dunno man I thought there were two screws in a plate that had to come out.
richardfine
17
06-11-2016 12:48 PM
Scfsouth
18
03-20-2016 10:06 PM
1986F150six
02-09-2016 08:10 PM
78 F150
12-14-2008 12:29 AM
Kane150
07-09-2007 08:19 AM
150 ,
1989 ,
1997 ,
e4od ,
f150 ,
ford ,
manual ,
removal ,
remove ,
rod ,
shift ,
shifter ,
speed ,
transmission ,
truck
