1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Zone or procomp lift kit?
Old 03-21-2013, 11:48 AM
Ian123's Avatar
Ian123
Ian123 is offline
Originally Posted by Ginther
Anything more than a 2" level, you'll need an adjustable track bar or track bar drop bracket... AND a drop pitman arm. And longer shocks. And maybe longer brake lines. You shouldn't need a longer front drive shaft though.
A 4" lift will easily clear 35's from all I've heard and read.
Actually, the stock pitman arm is fine for a 4" lift. 6" and up is when you need a drop.
  #62
Old 03-21-2013, 12:11 PM
acf6's Avatar
acf6
acf6 is offline
I'm thinking I need a 4" lift...I don't think it'll look to big on a truck this long
  #63
Old 03-21-2013, 01:32 PM
Ginther's Avatar
Ginther
Ginther is offline
Really? Hmmm... Interesting. I was always told 4" need a drop pitman.
Since I've never seen that setup in real life in person, I would have to see the drag link and track bar angles to be sure. They need to be parallel to avoid bump steer.
  #64
Old 03-21-2013, 01:34 PM
Ginther's Avatar
Ginther
Ginther is offline
Yeah, CC Long beds are definitely battleships LOL!!
4" wont stand out much on that long of a wheelbase. Anything less will probably just look stock.
  #65
Old 03-21-2013, 01:37 PM
ncon's Avatar
ncon
ncon is offline
CT troopers might take out a tape? Not sure whats legal, but they are harsh!
My 2in procomps have settled in to a "strong inch" over stock height (5.4l) after 2 winters...rides awesome still, but could use another bilstien per side like bbender's setup!
with a heavier motor, or looking for the clearance, the 4-6 oversized springs may be well worth considering...
  #66
Old 03-21-2013, 01:38 PM
acf6's Avatar
acf6
acf6 is offline
Ill be fine in that regard, i have tons of friends on 6, 8" + lifts driving around no problems
  #67
Old 03-21-2013, 01:43 PM
bbender85's Avatar
bbender85
bbender85 is offline
i think it's a grey area. my 4" Pro Comp kit came with the drop pitman arm and track bar drop bracket. need? maybe not. but like you say keeping those angles flat will definitely help with steering geometry.
  #68
Old 03-21-2013, 01:53 PM
acf6's Avatar
acf6
acf6 is offline
The worst thing with the 4" lift is the price tag...thats why im wondering if its worth it. although i do agree, if i just put new x codes and keep the leveling kit, itll probably just look "stock"
never had a problem on my old truck running 35s on just a leveling kit, but i think the diesel will make even the new springs sag more and not look quite right
  #69
Old 03-21-2013, 02:00 PM
bbender85's Avatar
bbender85
what are they running nowadays? when i did mine it included front springs, rear add-a-leafs and 1" aluminum blocks, all u-bolts, drop pitman arm, drop track bar bracket and hardware, extended front bump stops, and four ES9000 nitrogen shocks, all for just over $700 shipped.
  #70
Old 03-21-2013, 02:03 PM
acf6's Avatar
acf6
acf6 is offline
A kit with those exact components is around $950. And then id need to add $50 for drop carrier bearing kit, and i refuse to run stacked blocks, and for 5" blocks i would buy OUO blocks (u bolt actually goes through the block, cant spit it out) for $250.
Pretty much biggest reason im just thinking stay with a nice leveled stance, cheap, easy, and dont have to do anything besides springs and adjustable track bar
  #71
Old 03-21-2013, 02:11 PM
bbender85's Avatar
bbender85
hard to tell yourself thats the right thing to do isn't ? i am in the same boat.. want to put 6" under mine with 35's on 20's but unfortunately i don't have $4500 of disposable income sitting around. i can say i do enjoy being able to pull in the garage.... well kind of anyways:
  #72
Old 03-21-2013, 02:13 PM
acf6's Avatar
acf6
acf6 is offline
hahaha, thats awesome. and yeah, still should look pretty good leveled out though
  #73
Old 03-21-2013, 02:19 PM
bbender85's Avatar
bbender85
you might be surprised what a wider wheel would do for the look too... my dad had 285's under his 1/2 ton leveled '04 chevy on stock rims, and the tires in my sig are 285's on 10" wide wheels, and i'd never guess they're the same size tire.
  #74
Old 03-21-2013, 02:23 PM
acf6's Avatar
acf6
acf6 is offline
chevys are just silly...you need like a 6" lift to clear 35s lol. my buddy had an 2000 chevy 1500 (just traded for an 06 6.0 actually) with 6" lift, 3" body lift and 35s and my old truck was still the same height with a leveling kit and 35s LOL
all that was on there was F350 blocks (f250) and a 2" leveling kit...35x12.5x17 haha
Big Red F250 SD
6.7L Power Stroke Diesel
26
12-17-2020 09:57 AM
Rcmgiasson
15
03-14-2018 10:41 AM
jfletcher72
06-20-2016 03:13 PM
380tommy
12-07-2015 07:55 PM
King-bRanch
63
04-03-2014 06:01 PM
Quick Reply: Zone or procomp lift kit?
