Howl in rear end, only when coasting
Old 04-25-2009, 02:47 PM
epper34's Avatar
epper34
epper34 is offline
My 06 F-150 has a loud howl (like mudder tires) when foot is off the throttle. In the last year I have had rear diff clutch packs, all diff bearings(2 pinion and 2 side) all replaced and now this load howl. The second I use the throttle it stops.
Has anyone experianced these symptoms?
Old 04-26-2009, 06:44 PM
Oldguy4's Avatar
Oldguy4
Oldguy4 is offline
Why did you have all that work done? Was it noisey before? How many miles on the rig? I haven't experienced this, but I remember from auto shop too many years ago that, that is a problem with setting up the way the pinion gear meshes with the ring gear. If it's set up wrong one way it will do what you describe and if it's set up wrong the other way it will howl on acceleration and go away on deceleration.
tmill28
19
11-18-2014 09:49 PM
joshofalltrades
19
06-07-2012 07:39 PM
prouty74
2004 - 2008 F150
10-05-2008 05:02 AM
hang10
1999 to 2016 Super Duty
12-11-2003 03:42 PM
Quick Reply: Howl in rear end, only when coasting
