ok this is what i found so far cuz i cant find my test light first off my rear tank has no fuel in it oops haha and while i was bleading the injector lines on top of where the fuel filter screws on there is sopposed to be a wire but it is all melted off what is this for? could this be my problem?
Ah, si the melted wire supposed to go on top of the wire? Cut the melted part of the wire off and insulate the end, this is the fuel heater wire and that gets power all the time the engine is running.
Are you able to track it down to a single device? I'm not 100% sure where the PCM relay is on the factory equipped E4OD trucks.
PLC7.3, would you happen to know?
Not sure about the '92-'94 trucks, but mine ain't got no relays on the passenger side front fender. The ECM/PCM/TECA lives inside the cab, either on the left side of the driver's feet or in the middle of the dash over the tranny hump, but not on the passenger side.
Have you tried resetting the FIPL on the side of the IP.
Sounds like there is a power loss for some reason with the voltage drop.....check the alternator connections. Could also be the regulator (internal) brushes. Do you get a flickering alt light.
Any loss of power would effect the trans it is electronically controlled. Does the light on the shift stalk illuminate dimly.......that could be a bad TECA relay.
how do you reset the FIPL? apparently when i bled the injecor lines today i didnt do a very good job now my truck is stuck at the movie theatre with 2 dead batteries and air in the injector lines it was fine after i blead them i drove about 20 miles with no problem i parked it for an hour went out started it up made it a mile and it died took a couple min to get started then this happened once no matter how far i pushed the gas it was like it was at idle and then it went again i got to the theatre and when i stopped it was surging at idle i shut it off went in to the movie came out it fired right up and then died i pushed in the shrader valve on the fuel filter and some air came out befor the fuel got there tried starting it and it sounded like it wanted to fire a couple times but would not start this is how i blead the lines i got fuel up to the fuel filter i cracked all the lines loose went in cranked a couple seconds got out tightened the linse that were wet from fuel went back in the truck and cranked came out closed up the rest of the lines and fired it up reved it up to about 2000rpm slowly brought it back down and then back up till it was running normal then let it idle on high idle when it dropped down i drove it did i do it right? or am i getting air back in the lines? oh and after the movie in the parking lot i saw my sopposed best friend with my ex cuz he pulled up to see what was going on that just topped the night off i am pretty sure if my truck was running there would be a nice imprint from my brush guard in the side of his cummins that would have gotten pushed across the parking lot
i went to try and start it today i had the escape hooked up to it with jumper cables and i put my boat batteries in it they are only 680cca but they have been sitting on the charger so they were fully charged and i couldnt get it to start it wouldnt crank that fast i blead the lines again i noticed in the clear line that goes to the ip there was a pocket of air and i could not get it out needles too say i couldnt get it started i will have to have my stepdad go with me over there later i pulled the batteries and have them on the charger now but i may have to push his duramax home haha
ok here is what the tranny shop told me it was some sensor or relay on the injector pump that controls the computer anyone know anything about this?
Fuel shut of solenoid? If that doesn't work then the injector pump won't make enough pressure to fire the injectors.
There is also a throttle shaft sensor (basically a throttle position sensor) on the side of the injector pump that affects the transmission, but not how the engine runs.
the throttle shaft sensor is this something i can replace myself? the tranny shop said you need a scanner but i figgured i would check on here first
They are talking about the FIPLS basicly a tps yes you can replace it you're self. Pete has all the info on that. I also have it on my hard drive if you PM me your email adress I'll try to email it to you.
oh and did you fix the starting issue? because that sensor could not cause that. It almost sounded to me like you were out of fule , had a restriction in the tank or your lift pump took a dump.
yeah i got it started here is what happened i had a little less than 1/4 tank and when i would stop go or turn it would suck air cuz the fuel would slosh around
