Bent Pushrods on my 1997 7.3 Powerstroke
Old 03-31-2009, 07:16 PM
millmike's Avatar
millmike
millmike is offline
Has anyone experienced or heard of pushrods bending? Driving down the highway last week my truck began missing and running badly. Upon removal of the valve covers I found #2 cylinder had bent pushrods a broken lifter retainer, the lifters were out of place just laying there. Any ideas what may have coused this?
Old 03-31-2009, 07:23 PM
KevinC.'s Avatar
KevinC.
KevinC. is offline
Hydrolock? I've read of a few other guys this happened to on here.
Old 03-31-2009, 07:37 PM
millmike's Avatar
millmike
millmike is offline
I can’t imagine how that could happen????? I was driving 65 mph at 2200 rpm when my truck began missing and running bad, It would blow white exhaust when I accelerated after that. I may have hydrolocked it when starting it after that.
After re-starting it never blew white exhaust again.
I am trying to understand what may have happened before replacing the pushrods and lifters.
Old 03-31-2009, 08:36 PM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
lifter could have seized
Old 03-31-2009, 08:52 PM
kawa's Avatar
kawa
kawa is offline
Millmike:
Had you done any type of maintenance or work of any type on the engine immediately prior to this happening?
Did you or have you ever used starting fluid to start this engine?
Just fishing.
Rog
Old 03-31-2009, 09:00 PM
Diesel_Dirk's Avatar
Diesel_Dirk
Diesel_Dirk is offline
I had a bent pushrod on mine when I got it, had a headgasket replaced prior. My guess it was installed or it hydrolocked because they didnt empty all the fluids from the cylinder.
Good news is they are real cheap from Ford....like $40 for 4...had to buy a pack of 4 in my case.
Old 03-31-2009, 09:23 PM
millmike's Avatar
millmike
millmike is offline
A seized lifter make since to me.
The only maintenance in the last couple of months was an oil change, fuel and air filters. This truck has never had a valve cover removed prior to this.
I have used starting fluid to start the truck a couple of times on very cold winter days in Jan.. I sprayed a quick shot into the air filter housing prior to cranking the truck.
Old 03-31-2009, 09:28 PM
millmike's Avatar
millmike
millmike is offline
My intake lifter came out in pieces, I believe my exhaust valve is bent.
There is a little mark on the #2 piston indicating to me the piston hit the exhaust valve.
I am puzzled on how this happened.
Old 03-31-2009, 09:35 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
lost the valve seats?
Old 03-31-2009, 09:48 PM
millmike's Avatar
millmike
millmike is offline
I am taking the head to the shop tomorrow to have it thoroughly checked out, and most likely the exhaust valve replaced.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 04-01-2009, 05:34 AM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
weak valve spring can cause it too. How many miles on the engine?
Old 04-01-2009, 07:23 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Well now, there's your problem! Ether will bend push rods. You're lucky there wasn't an explosion...well maybe there was, but it happened in the cylinder instead of intake.
Old 04-01-2009, 08:52 AM
millmike's Avatar
millmike
millmike is offline
The truck has 135K miles.
Old 04-01-2009, 08:56 AM
millmike's Avatar
millmike
millmike is offline
Thats a possibility I guess.....
Old 04-02-2009, 12:32 PM
DRRXR's Avatar
DRRXR
DRRXR is offline
Check out this thread, some pics are in there as well.
https://www.ford-trucks.com/forums/8...ve-covers.html
Quick Reply: Bent Pushrods on my 1997 7.3 Powerstroke
