1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Clamping cap to bed
Old 03-15-2009, 08:42 PM
fairlaniac's Avatar
fairlaniac
fairlaniac is offline
Clamping cap to bed
I bought a used Eagle cap, what is the proper way to clamp it down? See the picture. Do I place the top jaw of the clamp right on the fiberglass (as shown)? I'm not sure if this is correct. It seems as thought the teeth on the jaw would possibly tear up the fiberglass.
http://www.fairlanet.com/images/clamp-cap.JPG
thanks,
Old 03-15-2009, 09:00 PM
420CREW's Avatar
420CREW
420CREW is offline
thanks,
Mine are setup the opposite Not sure that it matters but the instructions said to put em that way.
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
That looks like the way the clamps are on mine. The cap was on my truck when I bought it so I'm only assuming they're on correct. Seems like they must go that way though, because if they were opposite, I think the top bracket wouldn't have enough "reach" to get up to the bottomside of the bedrail...?
Not such a great pic but serves the purpose I guess...
Old 03-15-2009, 09:02 PM
spinella's Avatar
spinella
spinella is offline
mine are the same way. i have a ARE cap.
Old 03-15-2009, 09:14 PM
Steve_250's Avatar
Steve_250
Steve_250 is offline
Ditto with a Leer.
Old 03-16-2009, 05:46 AM
fairlaniac's Avatar
fairlaniac
Thanks! I just wanted to make sure that some sort of spreader bar or inside reinforcement wasn't missing.
Old 03-16-2009, 06:26 AM
hanklin's Avatar
hanklin
hanklin is online now
Nope nothings missing,clamp an go
Hanklin
Old 03-16-2009, 08:12 AM
bohiaa's Avatar
bohiaa
bohiaa is offline
on my 150 the cover was clamped down this way, I didn't like it so I drilled it out and used bolts with large washers.
dont know if it made any diffreance but the piece of mind was worth it
Old 03-16-2009, 10:01 AM
dgsone's Avatar
dgsone
dgsone is offline
Yeah that's the way they go. Just be sure not to clamp it down to tight or you will crack the fiberglass. You also want to make sure you have some good foam tape under the mounting flange or you will all kinds of wanter leaking in.
AdamG238
Ford Truck Parts for Sale
01-07-2013 08:55 AM
phoneman91
10-05-2011 06:28 PM
Jimmy Pet
35
05-01-2011 09:02 PM
bjolie
Aftermarket Products
03-13-2004 11:31 AM
bigredneck61088
01-29-2004 04:19 PM
Quick Reply: Clamping cap to bed
