1987 f250 fuel delivery problem; no fuel delivered
After setting for 4 years. i filled it up with gasoline (460 ci) would not start. mannually primed the carb and it started. replaced accelerator pump on carb because it was leaking. started it up again. ran fine for about 15 min. then died. no fuel getting to filter. no power getting to pumps. fuses are good under the dash. is there a fuel sending unit i could check, or relay, or what?
I'd look for a relay in the power box on the driver's fenderwell, too. I don't know if this is how the truck is equipped, or not.
If it came from the factory with a carburetor, and I think the 1987 460 did, it probably has a mechanical fuel pump driven by the camshaft on the side of the block, lower front end of engine. Follow the gas line that hooks to the carburetor down and that should be the first thing it hooks to. I could be wrong here.
kpc3my
09-28-2015 05:53 PM
jawroper
05-26-2015 04:29 PM
Mr. Badger
01-12-2011 06:44 PM
synergy141
11-06-2010 09:24 PM
