Need Help . Please !!
I am trying to install a set of OEM fog lights in my 03 F250. I bought a set off of ebay and i also bought a factory switch from an 03 with the fog light option.I talked the seller into cuting the harness and leaving about 6 inches of wire with the switch. I thought i would have to splice it in an run power out to the fog lights. However my factory plug and wires were the same as the fog light switch. So i pluged the fog light switch up and use my test light to find the wire that powers the fog lights( It was Yellow).Now what i need to know is once the wire leaves the switch where does it go.? I've looked eveywhere and cannot find it in the engine compartment. Thanks
I think it's buried in one of those wrapped up harnesses. I just spliced onto the wire coming off the switch and used one of the customer pass thru access wires to run a new power wire to the fog lights on mine. Life was much more simple that way. My new factory switch works great and I didn't have to start ripping a harness apart.
cutlass
10-22-2011 11:14 PM
SilverBullet131313
02-04-2011 11:12 AM
