Sponsored by: Real Truck
Need Help . Please !!
Old Mar 4, 2009 | 04:46 PM
billpinsc's Avatar
billpinsc
Exclamation Need Help . Please !!
I am trying to install a set of OEM fog lights in my 03 F250. I bought a set off of ebay and i also bought a factory switch from an 03 with the fog light option.I talked the seller into cuting the harness and leaving about 6 inches of wire with the switch. I thought i would have to splice it in an run power out to the fog lights. However my factory plug and wires were the same as the fog light switch. So i pluged the fog light switch up and use my test light to find the wire that powers the fog lights( It was Yellow).Now what i need to know is once the wire leaves the switch where does it go.? I've looked eveywhere and cannot find it in the engine compartment. Thanks
Old Mar 4, 2009 | 05:35 PM
RonC80's Avatar
RonC80
I have no idea but I can get you back to the top of the list
Old Mar 4, 2009 | 06:07 PM
dchamberlain's Avatar
dchamberlain
These diagrams are for a 2004. But I suspect the 2003 would be the same. It appears the yellow wire goes to a relay in the Central Junction Box. I can find the fuse shown (F2.43 is fuse #43), but I don't seem to be able to find any information on which relay it is.
Old Mar 4, 2009 | 06:56 PM
joe chevy's Avatar
joe chevy
my 2004 f250 has a connector behind bumper on drivers side i assumed it was for fogs i might be wrong but take a look there note : assume
Old Mar 4, 2009 | 09:40 PM
bayou barataria's Avatar
bayou barataria
Your owners manual should tell you which relay it is.
Old Mar 9, 2009 | 07:46 PM
billpinsc's Avatar
billpinsc
Thanks guys , but I still can't find the wire once it goes though the firewall. Any thoughts ?Thanks
Old Mar 9, 2009 | 08:39 PM
F350-6's Avatar
F350-6
I think it's buried in one of those wrapped up harnesses. I just spliced onto the wire coming off the switch and used one of the customer pass thru access wires to run a new power wire to the fog lights on mine. Life was much more simple that way. My new factory switch works great and I didn't have to start ripping a harness apart.
Old Mar 9, 2009 | 08:51 PM
billpinsc's Avatar
billpinsc
Where can i find the pass thru wires. I read they are wrapped up under the dash , but I can not find them.Thanks
Old Mar 10, 2009 | 05:02 AM
F350-6's Avatar
F350-6
It seems like mine were up under the dash above the parking brake. It takes a flashlight and some digging to find them, but the ends of the wires have heat shrink on them so you'll recognize them when you see them.
justdoinbizbp
Feb 16, 2014 06:04 PM
fordguy2236
1997 - 2003 F150
Oct 5, 2013 02:42 PM
Paul Moody
26
Jan 17, 2013 07:16 PM
cutlass
Oct 22, 2011 11:14 PM
SilverBullet131313
Feb 4, 2011 11:12 AM
