F350 Doors
F350 Doors
Hey Guys,
I just noticed ( dumb on my part) that the truck I bought last year, 1977 F350 Super Cab Camber Special, has doors that are rusted out along the bottom were the door skin meets the door body.
Can I fix this by grinding out all the rust, using something like POR-15 and then fiberglass/bondo, or do I have to replace the doors. I don't think just a door skin would fix the problem.
Thanks for the help. You guys rule.
Jeff
"Good, Better, Best. Never let it rest 'til your Good is your Better and your Better is your Best."
Jeff
F350 Doors
That might work but if it was me I would get the inner door bottom and the lower outer skin and weld those in.
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
mopar=Mostly Old Parts and Rust
gmc=Got a Mechanic Comming
chevrolet= Cracked Head Every Valve Replaced, Owe a Little, Except its Trash
Russell
1968 F250 LWB 300-6
F350 Doors
You might want to look inside the door to find the extent of the damage. I had a door that looked great on the outside, no rust showing. I took a flash light and looked at the inside and found more rust than you can imagine. I replaced the door with a near perfect one for $45.
If you can see it from the outside, the inside has to have some rust too.
delaney
12-22-2005 10:54 AM
