Fan speed switch
Fan speed switch
Hi all!
Yesterday when i fired up the heater in my truck i noticed that the "#1" speed for the fan dosent work, 2,3,4 work fine but when the switch is at number 1 the fan stops. Has anyone else ran into this problem? Is there a way to check out the switch with an ohms test? or could the fan be the problem? By the way i just have the standard HVAC system, not automatic climate controll.
Thanks in advance!
Thanks in advance!
Seems like it's usually that resistor pack down near the passenger kick panel that is crapped out when one of the fan speeds doesn't work. You would need the wiring diagram to see where/what to check.
It's been awhile since anyone posted about that, but there are some old posts back there somewhere.
Got it working! I took the trim off the dash to get at the swicth, however i busted the switch while i was trying to get the connector off to see if i could ohms test it. Guess what... the switch that i broke was fine. It turned out to be the resistor that was bad. New switch, new resistor and everything works fine.
Thanks for the imput!
Alex
Alex
4_Econolines
01-17-2016 08:47 PM
1FastGambler
10-08-2012 07:56 PM
