points keep burning out
Hi there I have yet another problem with my 1973 F250, as the title says my points keep burning out. I have been told I need a "ballast resistor" to tone down the voltage into the coil and prevent the points from burning out. If I put in the ballast resistor would this stop the problem I have with my coil getting all puffy and bulgy? and is it possible for these to explode? Would it be better to just to convert the system to electronic ignition to eliminate the points, condenser etc. Finally can someone send me a picture of what a ballast resistor looks like. Because my dad says there's a ceramic block that goes on the firewall (apparently that's what a ballast resistor is) but I think that's for 72 and older.
Go electronic.
Either find a 75 and up F100/F150 and grab the distributor and ignition harness and the ignition module or buy a new electronic distributor(Not HEI style) Buy Ford Style with Coil separate from the cap.
Pretty easy job to do or buy an MSD box and distributor they come complete with wiring diagrams.
Throw the points away they are and will be nothing but problems.
Rick.
I went the same way except....
No more points no more problems.
Rick.
Crane Cams makes an electronic conversion kit for about $60, (NAPA part # 735-4820). I put one in my truck a few years ago. It replaces your points using the original plate and wiring. As I remember it took about 20 minutes to put in. I put Cranes high voltage coil (335-3134) in at the same time. It made a surprising difference in performance.
As easy as it would seem to go throwing shiny new electronic parts at your problem, in the end you'll likely find a lot of frustration when they get fried from your problem.
You stated a swelling coil? How many volts do you have going into the negative post of the coil? Should be no more than 9 volts DC.
As frustrating as points can sometimes be, they are pretty robust.
Josh
Josh
The Mopars use an externally resisted coil which needed the ceramic ballast resistor (NAPA ICR23), which is usually mounted on the firewall or inner fender. If I remember right, Ford up to 74 also used an external resistor in the form of a resistance wire. Meaning the wire between the ignition and the coil was the ballast, as opposed to the ceramic one.
Somebody correct me if I'm wrong....
