Clamp on 6637 mod
I've been considering doing jsut what you're talking about. Just measure the diameter of the outside of the intake tube.
Then, go to the Clampco website (Standard T-Bolt Band Clamps | Clampco Products) and order the t-clamp that fits that size range.
Before you install the new clamp, though, you'll have to trim some rubber ridges off the stock intake tube so the new clamp will sit flat on the surface.
Really? I'm using a regular SS worm-gear band clamp with no problems. I can't help with your question, but I'm curious why the band clamp isn't holding. That seems strange to me...
EDIT: I think he's talking about the clamp on the filter, not the intake tube, Pete. He's using a piece of exhaust between the two, so I'm assuming the stock clamp is hold the intake tube well enough.
Be careful with just clamping the intake tube directly to the filter -- yes, it works. I ran that way for a long time, but I noticed I had to keep tightening the clamp on the tube. I found out that over time, the pressure of the clamp squeezes the filter neck down and it will loosen up. It was so much smaller after several months I had a hell of a time putting the 4" OD exhaust inside it when I finally got to it. The new filter I eventually replaced it with went right in, and the regular SS band clamp is holding it in place nicely. Have a look:
Yes, on some of the early 99's you have to use a piece of exhaust tubing 4 inch, with approximately 40 degree bend in it. I have heard that some of the early 99's also have a smaller intake tubing and require a piece of 3 inch to 4 inch coupling.
Yeah, the earlies have a short intake tube. Far as I know, it's the same ID, though. You'll need something like this:
It's a short piece of 4" exhaust with a 120* bend.
(Thanks to Travis, "Up_There" for the pic)
EDIT: You can also order the late intake tube. Check with "FTE_Parts_Guy", I believe that's his screen name...
EDIT2: Here's a link to his site. I'm sure he could hook you up with the correct part:
http://www.trademotion.com/partlocat...?siteid=215005
